Do cyclists contribute to the cost of our roads? Nope. They should as they use them!!!!!!!
Of course, I do, I drive a car as well. But there are two types of cyclist, those who use a bike to get from A to B at a leisurely pace, and the
they both ride bikes, but at 75 my top speed is around 10–15 MPH, and at that speed sharing with pedestrians is not a problem. But the Lycia warrior is doubling that speed, and having mother pram and toddler on same path as the Lycia warrior does not work.
From Dolgellau to Arthog there is a cycle track with very little young children as the route is a bit too much for a stroll, but then the bit over the Barmouth Bridge is narrower and has a lot more traffic, so often the cyclist needs to get off and walk, to safely pass walkers.
The same applies with the Wirral cycle track, some bits the cyclist can go for it, but other parts have too many pedestrians, so I do realise there needs to be some rules to allow the mixture to work together.
As it stands cycles do not need to have a speedo, and mine works when I am pedalling, but when freewheeling it stops working, so I likely break the 20 MPH speed limit cycling through my village, but that is on the road not the walkway.
The problem is parked cars, be it a push-bike, car or pedestrian one can only see people who are taller than the cars, so cars with a roof under 4'6" and a bonnet and boot under 3' there is a good chance one can see pedestrians within a reasonable braking distance when doing 20 MPH or less, but get a van, or motor caravan or even a large 4 x 4 and then there is a danger.
The only way to allow only small cars is to have a weight limit, so a gross weight limit of 2000 kg will allow most small cars access, but the EVs are not small cars.
