CBB65 start capacitor?
20 Mar 2009
Potters Bar
Need one for a Stuart turner monsoon pump.
10uF but can only see CBB60 online.
Would that suffice?
This is the kiddy...
Some are marked + and - and the polarity matters, if they have no markings then it doesn't matter. Generally ;)
BTW, the one I linked to is an example only, there were a few that came up.
Same when I searched, but they were all metal casing and different terminal arrangement to the one I have, under that code (CBB65).
Yes, that was originally wired top left and bottom right... Which is why I marked it with a black sharpie.
So, is it the same with the one linked to above by @denso13
The four spade one is a different connection to the two spade one. Connect the cable to any spade terminal, one on the four, one on the two.
If you see what I mean.
You would think that ST would use similar capacitors in their later pumps, aint broke don't fix it type idea. I believe more modern 10uF capacitors ahould work without issue though surely? as long as it's the same μF rating then the motor shouldn't know the difference? Not an electronics chap though so couldn't be sure.
Just in case you could use it and didn't have it -
Just in case - https://www.plumbworld.co.uk/docume...hower-pump-service-kit-installation-guide.pdf
What's throwing me is that the original CBB65 capacitor looks more like the CBB60's currently available online and not the new CBB65's available!
They all seem to be metal cases with 4 and 2 prong terminals.
Don't want to wait for the wrong one and wouldn't know if it was wrong or another issue with the pump... ie the sensors... I have them all linked out at the moment.
Pump only runs when you give the body a tap with a hammer. I've removed all the water-side components so it's just a bare motor with shaft poking out each side.
