Newbie - Atempting Plastering Job
22 Sep 2004
Im attempting a small plastering job.
It's indoors, but in a small outhouse in the garage so the finish isn't too important.
I've knocked the old cracked (blown) plaster back to sound plaster and now need to re-plaster the area (about 2 square metres).
The plaster has been knocked off down to the brickwork.
This is my first plastering job and would appreciate advise on what type of plaster to buy. i'd prefer to use something that is already mixed and just requires water, but i'm really not sure what i should buy.
All i know is that it needs two plaster coats. The base and a finish.
Any help appreciated.
Andy
Andy
Andy
You will need to buy bonding plaster to go onto the brickwork and build this level with the existing, you will then need finishing plaster that is applied thinly to give you the final finish. This finish can be polished as it is drying. I find if you seal the walls with unibond or equivelent it helps.
Thanks Terry1234
Thats just what i needed to know.
What should is the plaster/water ratio be?
Andy
________________________
moderator
please note 10a which is here
Keep adding water to the plaster until you have the consistency of whipped cream. Add the water in stages, making sure that all of the water has been mixed thoroughly with the plaster before adding more. Be careful towards the end, because you do not need to add much water at the end to go past the required consistency.
When mixing i use a mixer that goes on to the drill, it takes the hard work out of the mixing just be carfull you don't mix it too fast, and run your drill afterwards unloaded to cool it down!!!
i did a right bodged job of a bit of plastering.. all lumpy and horrible.. and managed to make it look fine by sanding it down with wet and dry on plank of wood... just a tip should it all go horribly wrong.
When you put the 1st coat on to fill the gaps, get a long straight edge that reaches across the area your filling & slap a load of plaser in the hole & use the float to really push it into every crack. Then pull the straight edge across the gap making sure nothing is proud. "Then let it dry" The finish coat want to be like honey to treacle in consistency. Use your float to apply the finish plaster as good as you can to begin with, then stop & give it a mug of tea time. The worst thing with finish plaster is trying to work it from the off. After you left it for a few minutes, go back in with your float & a wet brush you can dip in water & finish off. You will find the plaster a lot more malleable.
I suspect the plaster might have gone off by now! It's been over 20 years...
