12 Volt winch
28 Aug 2024
I have obtained a 12 Volt winch out of a Motobility van which was used to winch up a ramp a wheelchair including a patient. Its a compact unit and only has two wires coming from it Red and Black if i couple it to a battery it works and if i reverse the wires it works in reverse.
What I need is some information and hopefully part numbers and a wiring plan
I want to mount the winch on a wall and use it to pull a wheeled motorcycle up a ramp onto my Bike lift.
I have a big 12 V battery of 100amp spare to use. I want to also have a cable remote that is sprung loaded to off position so that i can control the movement backwards or forwards while holding my bike upright up the ramp stopping when i let go of the switch.
A wheelchair and a person cant be more weight than a bike going up a 6" ramp I need this to save my back due to old age.
Can I ask how to do this? The plate on the winch says fit a 25 Amp fuse to the battery live wire.
