12 Volt winch
28 Aug 2024
I have obtained a 12 Volt winch out of a Motobility van which was used to winch up a ramp a wheelchair including a patient. Its a compact unit and only has two wires coming from it Red and Black if i couple it to a battery it works and if i reverse the wires it works in reverse.
What I need is some information and hopefully part numbers and a wiring plan
I want to mount the winch on a wall and use it to pull a wheeled motorcycle up a ramp onto my Bike lift.
I have a big 12 V battery of 100amp spare to use. I want to also have a cable remote that is sprung loaded to off position so that i can control the movement backwards or forwards while holding my bike upright up the ramp stopping when i let go of the switch.
A wheelchair and a person cant be more weight than a bike going up a 6" ramp I need this to save my back due to old age.
Can I ask how to do this? The plate on the winch says fit a 25 Amp fuse to the battery live wire.
no its all in the little box with the wires coming out of it.
Whoa no.
That will require something to do the switching, it even has the rings crimped on the wires to bolt directly on the solenoid.
