I’d like to add some permanent lighting to my loft. Currently, the loft has a double socket on the upstairs ring and that double socket has a fused switched spur to a towel heater in the top floor bathroom below.
I’m planning on using three 16W batten lights from Screwfix.
Firstly, is acceptable to add a second fused switched spur for these LED loft lights? Should I connect it to the double socket on the ring or the existing fused switched spur? I’ll use a switched fused spur as it’ll be located above the loft hatch and thus be convenient to turn on without a separate switch.
Secondly, what rated cable should I use to link from the existing installation to the new switched fused spur? I’ll use 1mm² twin and earth after the switched fused spur along with a 3 amp fuse.
Finally, given that the lights fittings have no earth connection, I assume I should otherwise still use twin & earth cable and connect the earth up throughout the system? I’ll use junction boxes to connect the light flexes to the twin & earth cable and to allow the cable to go in different directions to each light from the switched fused spur.
Is there anything else I need to consider?
Thanks in anticipation
