What is my best way of protecting oak skirting board and architrave?
I am going for an engineered oak floor. Will OSMO also bee good for the floor?
I am going to test hard wax oil, osmo and osmo raw on the skirt to see which I prefer.
Does an engineered oak floor need underlay? It will be going on a concrete floor.
If I do need underlay what type do I need?
I am also replacing my floor. That will be done after the skirting board and architrave
If you're replacing the floor covering then this should be done before reattaching skirting and architraves. The floor sits underneath. Otherwise, you're left with a gap around the edges needing a quadrant of some sort.
I'd replace the floor first then the Skirting and Architrave. That way the expansion gap at the edges of the floor are hidddn.
And you will need to cut the bottom of
the door frames off so the floor with its underlay can slide under
Is this underlay ok?
To fit the underlay do I need anything else besides joining tape?
Is this joining tape ok?
This is hard lol. I just watched a video comparing laminate, engineered oak and vinyl flooring. In the video guy did a few tests to see how each did. He did deliberate damage. Things things like dropping a pointed knife, getting a couple of dogs running around to get scratches from their paws, water absorption test, moving around on a computer chair to see what damage that did, etc. The vinyl flooring came out best in nearly all of the tests. I may switch vinyl flooring.
Would you go for vinyl or engineered oak and treatt with polyx?
If switch to vinyl flooring would I still treat it with polyx or not?
No. (And neither would you treat wood with polyx oil if it is supplied lacquered, for example. It is applied to raw wood.)
Note that some of your questions above (e.g. about underlay) should be answered by reading the flooring manufacturer's instructions - and then checking with the experts here if they're unclear. Don't ignore the actual instructions "because someone on the internet told me to" !
Thanks for telling me about the laquered wood. What about if the engineered wood has been brushed and oiled? Would you you treat it with Polyx or not?
This is the flooring I have been looking at
Vinyl flooring?
I had laminate then swapped to engineered oak and the oak feels warm to stand on compared to the laminate.
As for damage I have dropped heavy stuff and it dents rather than chips like laminate. And you can sand down the oak and re varnish.
