I wonder if somebody can help me please.
I have a HW systems fed by a Worcester Combi boiler. One side of the house takes the hot water direct from the boiler, the other uses the tank from the previous gravity fed system.
Whilst the water direct from the boiler is hot, the tank doesn't have any hot water and from what I can gather is not sending a signal to the boiler to activate. Running the hot water does not fire the boiler.
I have removed the timer and connected the 1 (live) and 3 (HW) together but that made no difference. I also changed the water tank thermostat - again it doesn't appear to have made any difference.
Is there likely to be motorised valve and if so where would it be - e.g. on the pipes or in the boiler? Is there anything else it's likely to be?
I appreciate any pointers, advice please. I hope this provides enough info.
