This subject gets very complex, and way over my head, but in simplistic terms, over ranges of temp and pressure likely to be relevant in context, it's generally true that, for any given pressure (within that range), there is a temp below which the substance will inevitably be liquid and, for any given temp (within that range), there is a pressure above which the substance will inevitably be gas. A simplistic 'phase diagram' for an HFC refrigerant may help you to understand ...This isn't something I'd ever thought about as it's not my boat. However I don't know how dependant the process of liquification of gas is on temperature.
You need to concentrate on the regions labelled "Liquid" (light green) ans "Vapor" (light pink). We're not interested in the solid phase (white) and, as for the other three (when pressure and/or temp is/are above the values at the "Critical point"), they represent weird states ('above my head'!) where liquid and gas are not really distinguishable from one another!
so, simplistically ..... for any temp within that region, increasing the pressure will eventually cause the gas to become liquid, but with an increasing amount of presure required to achieve that at higher temps. Conversely, for any pressure within that region, decreasng the temp will eventually cause gas to become iquid but with an increasingly low temp required to achieve that at lower pressures.
Does that help at all?
