Smart adaptors, and what they do?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I needed some more for fans around the house. The main thing is the auto off timer, my old fan had a timer built in, so would auto stop, new ones that function is missing.
I use Tapo (TP-Link) in the main, so three versions look the same, P100, P110, and P110M the P100 does not have the timing function and does not monitor energy use, and as a box of 4 there is 50p difference in price, so left with P110 and P110M I have looked at the description, except for M version being more expensive, could not find the difference, and Screwfix only sells the P110M as single units, so it works out quite a bit more expensive, so settled with the P110.
But I have a few smart adaptors, the first one I got was Energenie, this one actually produces a graph of energy use, and will link direct to PC, however the Tapo dimensions are such that one can use them on a 4 way extension lead without them fouling each other, the Energenie are larger, and so is the odd Drayton Wiser I have, bought really to act as a relay station for a TRV head, (they use zigbee) but it was far more expensive, and does not do as much as the Tapo (except for relay function).
Hence, starting the thread, in the hope others will add how their plug in units have worked. The Energenie I have the monitor only, and switching and monitoring, there is also a switching only, the latter will work with the remote control, the combined monitoring and switching works with Google Home, and is the odd one out in it works with a PC, the rest other than Energenie need an emulator to work with a PC. It has now and over last hour 1782975831531.png and also daily and around a month, in same fashion, but rounds the corners off on the graph, and can be set with electric costs, so it shows totals in kWh and £, working over 3 months. It is the oldest I have, now around 10 years old, and I have used it to monitor freezers and car battery chargers, to see if auto defrost works, and it is still switching on/off at same rate, so warning if getting less efficient I use the monitor only version on freezers don't want them switching off, and on the battery charger it allowed me to learn a lot more about charging lead acid batteries, and to monitor without needing to go outside.
The P100 Tapo is very basic, it allows remote switching, but no energy monitoring, 1782977423721.png they look very similar, one only gives run time, the other gives runtime and energy use. The Lidi unit I have, is basic in comparison 1782977793098.pngIt has a Schedule and countdown, but have to access the app each time to set it, where with the Tapo the 1.5 hour setting used with my AC, is auto reset each time turned off, and means condensate bottle does not overflow. The tapo also has power protection, 1782978152089.png not used it myself, but there if wanted.
The Drayton Wiser does not do as much as the Tapo and the Wiser app is very slow to load. It does show wattage 1782978570300.png and a schedule can be set, but at double the price would have expected more. But it uses zigbee, and I needed one to relay for the TRV head.
I also have two power strips, a Lidi one, three sockets and four USB outlets, and an Energenie just 4 sockets, 1782978835106.png1782978980040.pngin both cases, on the unit you switch all sockets together with a single button, individual sockets can only be selected on the apps. On/off schedual can be set, but they are a bit basic, however, a lot cheaper to getting 3 or 4 smart single socket adaptors. I have got one remaining smart installed socket, Energenie, but had them turn themselves into flasher units, and although had same fault with plug in devices, much easier to change a plug in unit when it goes wrong.
So anyone got the Tapo P110M who can say what if any extras it has, or anyone got one of the many other makes? Shelly it seems do two, British General do one, Philips, Status, TCP, Sonoff, Moes, Hive, etc. Some designed for lights and can dim them as well.
Also what used for, in the main mine run fans, lights, and the AC, mainly where there is no option to use a smart bulb. Some are now quite cheap 1782980318927.png1782980388840.pngSimple timer is still cheaper, but not by much, and being able to turn on my portable AC while still on the way home is a plus.
However, tumble driers, washing machines etc, once off at mains will not auto switch on, not that I want to run them when not at home, but today so much is like that so no option to add any remote control. Now I sit back and see what others say.
I could never see the time-saving or convenience aspect to most of these gadgets
Mostly spend more time messing with them than time saved and doing tasks that don’t need doing
Edit ; meant as a controversial opinion btw not a put-down
Many, if not most, washers and dryers have delay timers built in to run when 'more convenient'.
Some now come with wifi connectivity... My washer is like that and I can (but never have) select the wash program and start time via its' Miele app.
I read about charge guard, which it seems monitors the power used, by a battery charger, and once it drops below a set level, starts a timer to turn it off, I can see with my drill batteries this 1782989383102.pngwould be useful, as the 6 green LEDs which show when batteries are fully charged light up the bedroom. But to spend £10 to auto switch off the LEDs does seem a bit OTT. As to the car battery chargers, the whole idea is that it auto switches on at below 12.8 volts, and off at 14.4 volts, which in practice gives the battery a short spike of a charge every so often to keep batteries A1.
I am sure the lithium battery charger turns fully off, but out of interest, I will test it.
Yes mine is like that, next version connected to internet.
Well it would seem the charge guard is doing just this, OK years ago battery chargers would say 16 hours maximum, and it seems they were rather cheap, but today most are designed, so batteries can be left on charge until next use.
Although I have seen a problem with that, mainly with PMR radios, where the base station one was left on the charger, which would auto switch off once charged, and not switch back on again, but the smart socket would be doing the same thing.
It seems I can set electric cost, but each hour, and my tariff changes at 00:30 so it will be slightly out, and I have guessed when the batteries will run out, which is the other change in price.
Well test done. 1782992268293.pngNotice given on phone, the battery charger 1782992338309.png showing bright lights. But as to why one would want the feature, not so sure! Although telling me when the batteries have been charged may be handy, but I like to have a rest between discharging each set of batteries.
So have a lot of us recently and, thankfully, they invariably come with proper switches.
Maybe I'm just old-fashioned (certainly can't deny being old :-) ) but I do have to wonder why the need for fans should bring about discussion about some new-fangled way of switching them on and off ;)
More about switching them off. The old fan I bought on holiday in Spain has a built-in timer, and would switch off after time set. All the new ones seem to not have timers, and to direct the air around the room the whole fan turns, where old one, had a disc with directors which moved where the air is directed something like this
. Seems we are going backwards with designs.
I will admit years ago the charge module had no control, just a warning not to charge over 16 hours. Today most of my chargers are smart in some way, and one can just leave it plugged in. However, just been on a bike ride on my e-bike, 12 Ah 48 volt battery completely discharged, so watching to see how long it takes to recharge, with the idea could take charger with me and call in a pub or somewhere to get it recharged.
Charging at 107 watt, so my guess is 6 hours, which is a bit long to stretch out a pub meal to. 16 miles today, I really did expect the battery to last out, specially when you realise I was pedalling too, not just sitting back and let the motor do the work. In the past I have got 30 miles out of the battery.
But down to my age, to nip upstairs to put a fan on before going to bed was OK, to crawl upstairs to do the same is something else. The older I get, the more I want technology to do for me.
However, be it a TRV head or a smart socket adaptor, or even a smart bulb, no one seems to talk about what they will do. So as a buyer, we just stick in a pin, no one seems to want to say, Hive version will do this, or Tapo will do that, and I hoped I could get people to talk about what there units do.
OK the battery charging option is a bit of a niche market, but the Tapo is not expensive as socket adaptors go. Compared with Drayton Wiser, which is far more expensive, it seems to do far more.
As to zigbee (Wiser is zigbee) I am not sure if I need an independent zigbee hub, or would the Wiser one have done all, but got the independent hub first.
1783012999078.pngIt seems likely I was correct, to see power used like this, does help to work out what was used. Max the motor can produce is 350 watts, seems likely I produced 250 watt, but max speed limited by gear ratios, around 12 MPH is my sustained speed, but motor could easily get to 20MPH, at help level 5, so using help level 3 for most of the return run.
But the charge rate is rather slow. I suppose I was just asking too much, however, without the energy monitoring, I would have no idea as to how long the recharge takes.
Yes at £8 each, having a timer built into the fan would be cheaper. But the timer is not built into the fan. 12 Ah at 48 volts = 576 Wh but used 507 Wh which points to the battery not being 576 Wh.
But one cost £10 and four worked out at £8 each, so was worth getting the group of four.
Fair enough, but not having any timer, anywhere, would cost even less!
I do understand, and sympathise with (since I'm a fellow-sufferer!), the problems that age brings to moving around (particularly up/down stairs) to get to switches etc. but mankind has managed for over a century since the first appearance of electric equipment (and had to manage with attention to gas, oil and candles before that), so ........ ;)
