Two way lighting not working
14 Jul 2026
Hi guys I have changed my two way light switches for new ones and wired the same way, had to extend the wiring as to short as had to move the switches abit to put new box in the walls,have connected up as before but neither are working, I fint have a electrical tester either ,swapped wires around from original switches and got one working downstairs, then one worked upstairs but not together, so just wired up as originally done,I took pics so I know it is correct ‍‍
Maybe go and buy a cheap tester? Or employ an electrician? Unless you can confirm correct voltages, I doubt wiring advice would be beneficial.
One of the switches is wired as 1-way not 2-way ?
The pics of the wiring on the original switches, i had no issues all working fine could turn lights on and off from either switch ,i post the new switches,i had to extend the wiring as I moved the switches over,maybe the connectors are not 100 %,I will buy a tester i guess and check gor power either side of connector
Not possible, they likely pulled out when you removed switch
there must be three connections for two way switching to work.
Sorry the picture not as intended, the at moment empty terminal will have the unused wire either red or black from two core, and the blue from three core.
In your picture above ,post no.8,( with the 2 red and 1 yellow wires connecting to a new switch) check the wire going to the com terminal.
This is how two-way works. you're red shown grey here from com to com must be correct, you have red and black which must go to S1 and S2 and blue and yellow also must go to S1 and S2 swapping red and black does not matter, or blue and yellow does not matter.
