Hi
I am trying to repair a cfl floor standing reading lamp which has snapped off at the base part of the cast thread has broken away. there was only about an inch of thread being used but can see a fix which is to use a longer threaded rod and add some epoxy around the broken part.
My problem is I cannot find the correct size rod. It measures 11.8mm outside diameter including the thread and inside is about 9mm. In inches the outside is just a bit smaller than 5/8.
The other issue is that the thread is 1.25mm pitch according to my pitch gauge but everything seems to be 1.0mm. Also i need it to be about 10cm or 12cm long.
I have searched the net with no luck.
Thank you.
Thank you.
