- Joined
- 15 May 2023
- Messages
- 58
- Reaction score
- 0
- Country
There's been a bit of a mistake with the bricklayers (long gone) and the height for the bifolds in my extension - essentially just too high. To avoid putting astep in before the door, I'm considering putting PIR over the whole floor, instead of between the joists. This should sort the level height, won't be too damaging on the CH (still at 2.55m after this), and would be way easier to fit. My questions are:
1. Is this a valid way of insulating/ fine for building control?
2. What would the build up be? I will be installing wunda underfloor heating, so imagine it would be 22mm boards, PIR, the wundaboards, then floor covering, but unsure if it needs a second layer of chipboard.
3. Is there anywhere I can find a reliable u value calculation? I can't work out how much insulation is needed, as all the calculators are for insulation between joists.
