UFOs
The object was also still visible sitting in the same position and same shape, later as the grid fin camera slowly moved bringing it back into view in the now distance at 8.50 to 9.07
Lens flare.
You clearly have not looked at the section of vid in question - it is 100% not lens flare. Have a look at the vid, it includes lens flare and the object slowly appears from behind starship as it moves and the object is stationary and the same object is still there at around T=9.00min and by now at a greater distance as starship has moved in semi orbit.
Here I cannot isolate the relevant section so you will ave to fast forward to T=6.50 starship time or 1 hour 11min whole vid time
And before anyone says its the moon - here is the moon - even talked about and pointed out in this vid at 6.40mins in. It looks very different from the object in question. Also interestingly this talkthrough using replays of the launch completely cuts out the section that contains the object
Says you. The video is full of artifacts from lense flare, why not this?
That should be your first clue it isn't a UFO. Stationary relative to the earth means it's defying the laws of gravity and floating.
Stationary relative to the spaceship means it's also in an unstable extremely low earth orbit that would decay in hours at best. Or in other words following starship on a deliberate intercept.
Slowly getting further away (smaller) means it is falling out of orbit. It would have been visible as it burnt up.
Then think about the scale in space. That ship is traveling at 7km/s. Are we witnessing a ship the size of the great pyramid or something bigger?
Or its light reflected from the cloud layer that's refracting in the cheap commercial camera lenses SoaceX use. Which explains why it stays in the same place relative to the earth and sun.
Stationary relative to the spaceship means it's also in an unstable extremely low earth orbit that would decay in days. Or in other words following starship on a deliberate intercept.
Every single one of your comments here is clear indication that you have not watched the vid section in question.
I did, you've got to be particularly desperate to believe in UFOs to make that jump. But please let me know what you think this supposed object is doing, orbiting or not orbiting?
