How do I connect to the male thread of a dielectric coupler?
28 Apr 2008
Gloucestershire
I'm fitting an Ariston Andris hot water cylinder and I've hit a bit of a problem with the dielectric couplers on the top of the tank. The dielectric coupler is shown on the left of the picture below. It screws down on to the top of the tank and has a rubber washer to seal it to the tank, this is fine.
The problem is connecting the male end of the dielectric coupler to the rest of the pipe work. I bought the brass 1/2" BSP female to 15mm coupler to attach to the male end of the dielectric coupler. The male threads on the dielectric coupler are much to short to compress to the washer that I'll put in the brass coupler. I'd need probably 3 washers to fill the gap internally!
Interestingly, the flexible tape connector has the perfect fitting. The female threads on that are short enough the dielectric connector would compress the washer.
What am I missing here?
I believe these are all parallel threads so should seal using a washer. I've found several examples of people just covering the threads with teflon tape and calling it good, though.
Go to a plumbing shop and get a different brass coupler, take the plastic one with you to confirm it does fit.
As often seems to be the case I think I've figured out what I need 5 minutes after posting. I think I need the things shown below. 15mm to 1/2" bsp tap connectors (there's also a compression version but this is fine).
All the tap connectors I've looked at have this shorter section of female thread. My guess is the designers of the water heater expect most people to just run flexible hoses straight to the tap or something.
That won't work as the centre part of that tap connector would have to fit inside the plastic fitting and i don't think it will. A few fibre washers inside your female fitting and ptfe tape or jointing paste will probably sort it.
As above... There are short socket female irons available - I have had to get a bag of them as have been having to fit a lot of instant water heaters in garden rooms recently.
Check with local independent merchants. Not nationals.
What's the significance of dielectric? Is it to stop any electrical path between the tank and the pipework, though I can't see why that would be be a problem. Can you use a brass fitting instead?
To prevent dissimilar metals corrosion. It's in the instructions so will be needed to keep the warranty.
OK, I suppose the cylinder is stainless steel. Had a quick google, but info on Ariston cylinders didn't jump out! Does that apply to all the connections? I'd bet plenty of SS cylinders have been installed with all metal fittings and pipework.
I'm assuming it's a water heater, that's what that model is, and there are only two connections with one on each.
