I'm fitting an Ariston Andris hot water cylinder and I've hit a bit of a problem with the dielectric couplers on the top of the tank. The dielectric coupler is shown on the left of the picture below. It screws down on to the top of the tank and has a rubber washer to seal it to the tank, this is fine.
The problem is connecting the male end of the dielectric coupler to the rest of the pipe work. I bought the brass 1/2" BSP female to 15mm coupler to attach to the male end of the dielectric coupler. The male threads on the dielectric coupler are much to short to compress to the washer that I'll put in the brass coupler. I'd need probably 3 washers to fill the gap internally!
Interestingly, the flexible tape connector has the perfect fitting. The female threads on that are short enough the dielectric connector would compress the washer.
What am I missing here?
I believe these are all parallel threads so should seal using a washer. I've found several examples of people just covering the threads with teflon tape and calling it good, though.
