Not things I`d be thinking of myself but as I have seen them then some folk like them so its another choice if needs be.
True. I suppose that oil lamps and candles are also 'other choices'Not things I`d be thinking of myself but as I have seen them then some folk like them so its another choice if needs be.
Bear in mind that the kitchen is almost unique in that a majority of the time you are working close to and facing the wall and hence creating a high risk of shadow on your work space, as such I'd avoid point lighting and my choice has always been linear fluo's and the longer the better simply to cut down shadows.True. I suppose that oil lamps and candles are also 'other choices'
To be serious, though, I was only really thinking of considering 'mainstream' things - so I guess primarily LED tubes, LED panels and, perhaps pendants (and also 'maybe', if circumstances made it desirable, also 'supplementary' things like wall lights and spotlights) and (if I had wall cupboards) under-cupboard lighting.
As you are presumably aware, that's what I have been thinking and saying all along. As I said very early (and have essentially 'stuck with') my main thinking (pending input and advice from others) was to replace the one 5' 'tube fitting' (now LED) which I now have, with two like that, in-line, so as to cover as much of the length of the room as possible.Bear in mind that the kitchen is almost unique in that a majority of the time you are working close to and facing the wall and hence creating a high risk of shadow on your work space, as such I'd avoid point lighting and my choice has always been linear fluo's and the longer the better simply to cut down shadows.
Whilst, as I have said, I certainly agree that 'point light sources' are undesirable in locations like kitchens and workshops etc. (maybe even some offices etc.), and whilst I don't disagree, conceptually, with anything you say and illustrate about shadows, I think that, in practice, the shadow issue is nothing like as bad as one might expect....... with a run of wall cupboards and cooker hood opposite the door, creating a shadow was nigh on impossible other than the wall cupboards themselves. ..... Roughly speaking this shows a 3m wide kitchen with 600mm worktops both sides, single light at 2.4m ceiling and 1.8m person standing at worktop
.... Dark grey shows shadow cast by the shoulders/body and light grey shadow cast by the head.
@SUNRAY I think that you and I were very close in our thinking about this, so I'd appreciate your thoughts and advice as regards 'where I am now'.As you are presumably aware, that's what I have been thinking and saying all along. As I said very early (and have essentially 'stuck with') my main thinking (pending input and advice from others) was to replace the one 5' 'tube fitting' (now LED) which I now have, with two like that, in-line, so as to cover as much of the length of the room as possible. ... However, on reflection, they don't need to be 'tube fittings' - a panel of similar length would presumably be as good, light-wise,and might well look better. Although, like so many others, I've used fluro tube fittings in places like kitchens, I have always felt that they look rather 'industrial' for a domestic environment - so I would probably regard it as a bit silly to go with things like flameport suggested, which do not contain tubes but have been made to look as if they do! I think that 'long panels' would probably look much more 'domestic'!
Yes, I looked at them when he mentioned them 'way back'Have you looked at those linked by Rocky way back in the thread. .... My first sensible hit is TLC ....
I suppose that, despite what you and others keep saying, I remain a bit nervous about how bright a pair of those might be! In general, I'm a great believer in "everything in moderation" ("happy medium") - an this seems to be way beyond that.I suspect you will feel somewhat different when you realise how much better the additional light level is.
Oh no I'm certainly not one who says it can't be too bright, that is always one of my complaints about downlighters.Yes, I looked at them when he mentioned them 'way back'
A pair of those 5' (1,500 x 200mm -which is an ideal size) lights would appear to amount to 90W and 9,580 lumens - which, in broad terms is about 5 times more that the current 17W / 2,030 lumens which, as I keep saying, really is not doing too badly. That's an awfully big 'jump up'![]()
Imagine that, in the days of incandescents, you had been asked about a room which was 'not too badly' (but not ideally) illuminated by, say, a 60W bulb -would you really have been suggesting that they should try 'upgrading' the 60 W to 300 W ?
You, and others, seem almost to be taking the view that there is not such a thing as 'too bright', but I would suggest that there is one, pretty common, situation in which that simply is not the case. As occurs in a high proportion of people, as I grew old my eyes very slowly, and very insidiously, developed cataracts. I eventually had surgery on both eyes about 18 months ago, and it is only when that happens, resulting in a sudden and dramatic improvement, that one realises how poor one's eyesight had become! The point is that what led me to realise that the surgery was needed was the fact that I had come to be in the position that bright light almost 'blinded' me - 'blinded by car headlights' is a very common feature of earlier cataracts and, talking to others, it seems that 'blinded by any bright light' is an almost inevitable phenomenon with advancing cataracts!
Despite my nervousness, I suppose I'm going to have to "grasp the nettle", put my trust in you guys and go with the sort of 'seemingly over-bright' lighting we're talking about! It's a pity that the TLC ones are not dimmable (does anyone know of any similar ones which are?). I fear it might be difficult (messy and disruptive) but I'm going to look and see how easily I could install separate switching for the two lights - since I could then at least switch one off if I had to!
OK - but, in that case, why do you not seem to share my fear that products supplying about 5 times more light than does my present lighting (which "isn't at all bad") might well be 'far too bright'??Oh no I'm certainly not one who says it can't be too bright, that is always one of my complaints about downlighters.
My impression of LM levels from Fluo and LED is there is a mismatch and I think it's due to the different colour spectrum between the 2 formats.OK - but, in that case, why do you not seem to share my fear that products supplying about 5 times more light than does my present lighting (which "isn't at all bad") might well be 'far too bright'??
There's something about all this which I just don't get.My impression of LM levels from Fluo and LED is there is a mismatch and I think it's due to the different colour spectrum between the 2 formats. ... Comparing a CW fluo tube and a CW LED tube of similar stated light levels, shows a different colour rendition and brightness.
Welcome to my world at lastThere's something about all this which I just don't get.
In terms of LEDs, per se, (e.g. lamps/bulbs as used in pendants, it's usually assumed that the lumens/watt is 5-10 times greater with the LED than with an incandescent - hence about7-9W of LED is generally considered roughly equivalent (in terms of light output) to a 60W incandescent and 12-14 W of LED roughly equivalent a 100W incandescents. Furthermore, the wattage of fluoro tubes is roughly in the same ballpark as for incandescents - hence, for example, 60-100 W incandescent OR 58 - 70 W fluoro.
However, the moment the LED elements find themselves in a 'tube' or panel on a ceiling, all of a sudden their lumens/watt appears to have fallen to roughly the same ballpark as incandescents and fluros, certainly never more than about half the lumens/watt of an incandescent or fluro.
Put another way, I don't think that anyone in their right mind would, even if they could get one, even consider putting a 40, 60, 80 or 100 W LED lamp/bulb into a pendant socket, would they, even though such wattages don't seem at all unusual for the ceilong-mounted LED lights.
What on earth is going on?
How can the led elements lumens/watt be in the same ballpark as incandescent “and” fluoroThere's something about all this which I just don't get.
