JG speedfit stop end question
5 Oct 2014
Hertfordshire
I'm planning ahead for a project where I am going to need to use some JG speedfit stop ends on some plastic pipe.
I've bought a bag of the super-seal pipe inserts but I've noticed that they are labelled 'twist lock' while the stop end is 'standard connection'.
I presume that they are compatible as there didn't seem to be another option, but I just wanted some reassurance and to understand why they are labelled like that.
Thank you
The super seal are designed to work with the twist lock fittings. They'll work with stop ends but technically should just be non superseal.
No. You can cut off the insert a bit just behind the o ring on top, it then just becomes a normal insert.
