Assuming there isn't a NRV in the mains supply which will prevent the expansion, what is the max capacity allowed without installing a EV??
I think it depends on the distance from the unit to the nearest cold water tap. A 5litre unit requires about 2 meters a 15 litre around for litres. Other wise it's a single check valve and 2 litre expansion vesselAssuming there isn't a NRV in the mains supply which will prevent the expansion, what is the max capacity allowed without installing a EV??
That sometimes creates a bit of confusion as one might think that the pipework itself can accomodate the expansion, say ~ 0.3L with a 15L cylinder but it must have no restriction right back to the mains like a PRV or a NRV, its only, IMO, to ensure hot water doesn't come out the cold tap. A friend of mine had a 10L with its own PRV, see below, (pressure relief valve) which would start feathering very shortly after he switched on the heating element, he found a PRV (pressure reducing valve) on the mains and just removed it as his mains pressure never exceeds 3.0bar.
The cylinder had a Ariston 571730 combined PRV & anti syphon valve.View attachment 420551
I'm not so sure about that, the schematic below shows a pressure reducing valve but not a expansion vessel, the 2.8M or 4.2M required for expansion might give the impression that no expansion vessel is required, also the statement below can lead to confusion, IMO.Diagrams in the MI's are usually very good and explanatory.
