Repair surface water pipe?
2 Sep 2011
Lancashire
How do I best fix the hole in this surface water pipe? Just holding rainwater from the guttering. I guess it was made when that armoured cable was dug in. Replacing it entirely would be a lot of work so looking for alternatives. It's probably been like that for 10+ years.
I discovered when assessing how to lower (20mm) and level the hopper. Any advice on this too? I think levelling it is probably not worth the effort either. Can I just cut down the spigot to lower it or will I then not get the fitting in (as I'd have cut off the taper)?
Cheers
I was hoping for something less invasive as an interim (albeit probably for a while) solution until there's a better opportunity to fix properly. All I need to do is stop dirt getting in, not stop water getting out right. I was hoping someone would suggest some sort of patch
OP.
As above: dig it out & replace it.
For a couple of reasons the crack seems recent.
By the time you've messed about with digging to enable flash banding you may as well do it properly - plus there's probably more to the crack than can be seen.
Does the gully drain to a soak-away or a sewer?
Plus you could correct your gully ground surface level.
If your gully area begins to swamp during a wet winter then you might have cause to think on about cutting corners?
FWIW: Why not get the shallow depth of the elec cable checked out - (450mm - 500mm depth is usually safe)?
OP.
Drains to a sewer. I've seen no indication of water in that area in the 6 years we've been in the house. There's nothing I've done that has caused that hole so it's at least that old. I just don't want to get into digging it out and replacing it, and the hassle I might encounter. The armoured cable goes to a decorative lampost in the lawn. I knew cable was roughly there when I started, but yes shallower than anticipated. I think both are jobs to address when the drive is eventually redone i.e. patch up for now and on the long term list to fix properly.
Resin bond with off cut of plastic pipe, but seeing as you have done the biggest part of the job, its daft not to replace it.
Have I done the biggest part though? I've not got under it, the unexposed end is under concrete and depending on how long the piece is might also be under the drive, and I assume I'd have to take the hopper and the bit under it out to fit the new bit so even more digging around
OP,
Thank you for your reply, post #7.
Maybe you've not seen "water in the area" over six years because the pipe was not damaged six years ago.
There's also the matter of rats from the sewer would have found that crack & at that depth been coming & going for six years.
Rats will be thro any flashband or patch in minutes.
Anyway, good luck with whatever you do.
OP,
I hear you and in the interests of doing a proper job have excavated further. However, as per new image I don't see any easy way to replace the broken section like for like. There's not enough room to remove withiut cutting out the broken bit and then there's not be enough room to slot in the equivalent (unless I dig up the drive which I'm loath to do, and especially with that cable in the way). Friend more knowledgeable than I am has suggested maybe replace with a bottle gully and use a bend + straight with slip coupler?
It’s your property and you have something a busy contractor doesn’t have - time
Yeah, I'm going to head to the builders merchants at lunch and see what's possible. I'm wondering if I can get two 45's, a straight and a coupler to recreate the broken 87.5 piece, but I depends on measurements
OP,
Thanks for the last pic.
Break the damaged fitting, & lift out the hopper & whatever is connected to it - remove the cracked fitting remains. Post a pic?
The remaining damaged fitting is push-fit, & can now be simply removed by pulling back from where it connects to a pipe end just under the drive.
After installing a new bend then work back to the hopper.
A bottle gully might work but you have to remember that the drainage must be falling to the pipe end under the drive.
I've just seen your post #13, & now you seem to be in a hurry?
Why not simply remove everything I suggested above , & then pic what you have
