Repair surface water pipe?
2 Sep 2011
Lancashire
How do I best fix the hole in this surface water pipe? Just holding rainwater from the guttering. I guess it was made when that armoured cable was dug in. Replacing it entirely would be a lot of work so looking for alternatives. It's probably been like that for 10+ years.
I discovered when assessing how to lower (20mm) and level the hopper. Any advice on this too? I think levelling it is probably not worth the effort either. Can I just cut down the spigot to lower it or will I then not get the fitting in (as I'd have cut off the taper)?
Cheers
I was hoping for something less invasive as an interim (albeit probably for a while) solution until there's a better opportunity to fix properly. All I need to do is stop dirt getting in, not stop water getting out right. I was hoping someone would suggest some sort of patch
A bit of flashband will keep debris out and let you concrete over the thing if you wish
