It would probably shear through the layers the first time you used it in anger.If you have someone with a 3d printer, you could easily make your own 3 vane key
What would you use on your printer for this application then? Interested to learn.Depends on the material and the printer.
Aquam refused to discuss this item, & directed to a generic page of theirs, for water taps, none of which fitted this unit. The last query to them was simply unanswered.
Bournemouth Water have now fitted a plastic key to the stop-point.
No idea how, since the engineer arrived & departed unannounced.
One month ago an engineer claimed that recent plumbers had 'broken' the stop-point. That's impossible, because if the centre section shows damage, it would be bright & shiny metal. However, it is thoroughly tarnished with age, so if that was a break, it happened many years ago. And was never logged.
And if that plastic key replaces a metal one, what are the 3 vanes for, at the sides of the stop-point?
View attachment 420480View attachment 420481
That's the key they left, you can see it has two lugs either side, which prevents it fully engaging with the stop tap point.
I'd just get my son to do it... He has 3 printers and makes all sorts![]()
OK - fine. From personal experience I would advise anyone trying to make a 3D printed tool that has to withstand heavy torsion, to have some thought to how easily FDM printed objects will shear between layers. Without a novel design approach it would just be a waste of time. The problem is that the shape of the tool implies that the tool orientation is vertical on the print bed, so the shear would be applied directly between layers. And apparently, resin printers are even worst in this respect.I'd just get my son to do it... He has 3 printers and makes all sorts![]()
Could aways bury a rod in it![]()
