Thanks for responding.Unless it is restricting the pressure sensor reading, I would say no.
It wouldn't do any harmIs it worth trying cleaning it as I am thinking to not do more fault finding on this like pump etc before I just change the boilor ?
Absolutely it could.Could the pump be overheating causing F9 then when it cools lets boilor reset ?
Thinking put a thermal camera on it tomorrow if pumps around 80 degrees and pipes close to it around 60 degrees . Then its the pump ?Absolutely it could.
Not necessarilyThinking put a thermal camera on it tomorrow if pumps around 80 degrees and pipes close to it around 60 degrees . Then its the pump ?
Is there anyway I can determine conclusivly its the pump ?Not necessarily
An easy test if it has a bleed/vent screw - remove this, being careful as water can trickle out to pour out if completely gone, create a demand and try and stop the pump, if you can without much force, I’d be looking to replace it.Is there anyway I can determine conclusivly its the pump ?
Understood thanks.An easy test if it has a bleed/vent screw - remove this, being careful as water can trickle out to pour out if completely gone, create a demand and try and stop the pump, if you can without much force, I’d be looking to replace it.
Just so understanding do you mean stop pump spinning with screwdriver once bleed screw is out and a call for demand ?An easy test if it has a bleed/vent screw - remove this, being careful as water can trickle out to pour out if completely gone, create a demand and try and stop the pump, if you can without much force, I’d be looking to replace it.
Kinda, place the call for demand first, then try to stop itJust so understanding do you mean stop pump spinning with screwdriver once bleed screw is out and a call for demand ?
