Glowworm Flexicom 30x pump
Understood . If I can stop it does this mean the pump could be falling when not trying to stop it and the boilor going into f9.
Yes the pump could be what we call weak, and therefore not enough energy to circulate the heat quick enough
If your boiler is a sealed system with a EV, note the boiler pressure with the pump off, start the boiler/pump, the pressure should rise by the pump generated head, ie, if the boiler stopped pressure is say 1.0bar and then rises to say 1.3bar then the pump head is 0.3bar/3.0M or whatever.
Boilor set to 1.0 bar. Im not at property now but think it raised to 1.1.
Sorry it was 1.2 stopped 1.4 to 1.5 running
Your Mis should show where the pressure gauge tapping point is, its probably after the boilers heat exchanger so should reflect the residual pressure after the heat exchanger's pressure drop, the MIs should show the HEX's pressure drop at different flowrates for the different boiler models outputs, if you can find this, post it. I don't know if the Glowworm pump has different pump settings like its Vaillant cousin so dont't know if a 0.2bar differential is enough to satisfy the pressure sensor or not, assuming its not blocked with sludge. Again the MIs may show where the pressure sensor is taken from.
Yes, can be this too. Unless you can test it and replace it, probably best with a new pump
Yes. I can probably test did it years ago on a tv circuit board but just got new pump. It was the old style Vailliant pump.Save me doing more learning with just getting new pump.
Sourced a new one for £80. Comes by Wednesday
