Understood . If I can stop it does this mean the pump could be falling when not trying to stop it and the boilor going into f9.Kinda, place the call for demand first, then try to stop it
Yes the pump could be what we call weak, and therefore not enough energy to circulate the heat quick enoughUnderstood . If I can stop it does this mean the pump could be falling when not trying to stop it and the boilor going into f9.
I could stop pump.fairly easy but not sure if a new one would stop that easy as first time ive done it .Kinda, place the call for demand first, then try to stop it
Boilor set to 1.0 bar. Im not at property now but think it raised to 1.1.If your boiler is a sealed system with a EV, note the boiler pressure with the pump off, start the boiler/pump, the pressure should rise by the pump generated head, ie, if the boiler stopped pressure is say 1.0bar and then rises to say 1.3bar then the pump head is 0.3bar/3.0M or whatever.
Sorry it was 1.2 stopped 1.4 to 1.5 runningIf your boiler is a sealed system with a EV, note the boiler pressure with the pump off, start the boiler/pump, the pressure should rise by the pump generated head, ie, if the boiler stopped pressure is say 1.0bar and then rises to say 1.3bar then the pump head is 0.3bar/3.0M or whatever.
If you could stop it fairly easily, I would go with that. Perhaps try on your own boiler/pump?I could stop pump.fairly easy but not sure if a new one would stop that easy as first time ive done it .
I have ordered new pump. Thinking it could also be capacitor in pump.If you could stop it fairly easily, I would go with that. Perhaps try on your own boiler/pump?
Yes, can be this too. Unless you can test it and replace it, probably best with a new pumpThinking it could also be capacitor in pump.
Yes. I can probably test did it years ago on a tv circuit board but just got new pump. It was the old style Vailliant pump.Save me doing more learning with just getting new pump.Yes, can be this too. Unless you can test it and replace it, probably best with a new pump
Great! Hopefully it will fix the issueSourced a new one for £80. Comes by Wednesday
