Fitting new hinges to a uPVC window - step by step.
1 Dec 2009
East Mids
I've been threatening to do this for a while but most days don't get 5mins to take photos, anyway hope this helps some who decide to have a go themselves or for those that jumped in feet first without thinking it through and are now in a muddle and the window won't close.
Maybe admin could make this a sticky for the top of the page so it doesn't drop off the bottom?
thanks, have no idea how to do it but having just been quoted £350 to replace 3 hinges on my 3 week old composite door (he claims my hinges are causing my door to drop on one side) this article should be stickied!
Also to note I did not pay £350 for new hinges!
An excellent how to thread.
With mine when I changed the hinges, I had the additional issue of getting the window sides to frame (120cm) even on both sides for a good seal. On the worst, the difference was 6mm so basically it was 6/2 = 3mm horizontal adjustment to get the frame even.
All I would add to the above is use stainless steel screws and not plated. Nowt worse that a rusting screw to spoil the look of a stainless hinge system.
Recently replacec my ancient side hung hinges.
Obtained stainless MILA hinges from Screwfix and replacement (slightly larger diameter than the original) stainless panheads from the bay.
Essentials for me was a pair of suction grip handles (£9 apx) to make handling the window units safer, and someone to pass me the screws during the initial securing of the top hinge - stainless screws do not stick to magnetic screwdrivers so needed to insert the screw by hand before I could use the screwdriver.
Some screw holes of the old hinges did not match the MILA replacements, solved by drilling new holes, clearance size in the hinge, smaller (apx 1/2 clearance) in the frame.
Tips;
Do not remove the window handles, they make an extra grip if needed.
Measure the old hinges twice before buying the replacements.
Expect the old screws to be of different lengths and drive bits.
Sucker marks can be difficult to remove, clean as soon as the sucker is removed.
Lastly remember the original windows were probably installed when UPVC was in its infancy, nobody was a highly skilled window maker or fitter. I found four different screw types, some screwed into fresh air, and worst of all the outer frame bent out of shape by over tightening of the screws, the cause of the draughts and a problem I have still to solve.
Thank you. I came here to ask about replacing a broken hinge. One of the screw holes does not line up, now I know that is normal. Do I need to drill a pilot hole in the uPVC and if so what size? I assume I do.
It would all.dwpend on whether the frame is reinforced or not. If other screws line up and its only one them you normally can just screw it in if the frames not reinforced. As for size , anything smaller than the screw
Unfortunately when I drill into the side of the window panel, I hit metal. Do I use a metal drill to deepen the hole, or drill a new hole in the bracket? Thanks. Of course the ideal is a hinge that fits. I think these were Anglian windows, fitted 25+ years ago.
Thanks all. I went through the metal and it’s all sorted, looks okay too.
As an aside, I have really horrible nasty Chinese metal drill bits, most are useless, some from B&Q, some from China.
