No hot water for 2 weeks (2 young kids)
5 Sep 2026
I don't know where to start. Every August my hot water stops Working. Nothing trips nothing has tripped resulting in any power Being lost that couid change the water. But now I can't get it back on. I'm a single mum with two kids (4 and 18 months) I can't afford a plumber. The Hot water works used to work for timed programme but the hot water hasnt worked on boost For a long Time. If I try Boast the water will always be cold.
The water system is controlled by a horstmann electric 7. The power supply works. The lights are on. Everything comes on. The water just doesn't heat up. I've Spent hours and hours and hours trying to resolve this.
Within the immersion heater, I've turned off the power supply to reset the thermostat. There seems no reset button. The temperature has been changed to plus. The water just wont heat up. I've Added Some pics and. To confirm again I've always got power supply Off when playing around with immersion heater. I took the stuff off to identify reset button with screwdriver but there is nothing
Do you own the property, or is it rented?
Do you own a multimeter? Do you have any friends who might own a multimeter and be willing to help?
Could be the immersion heater element, as it appears to be the only method of heating the water. Is it a hard water area? It should be serviced/repaired by a G3 registered engineer as it’s an unvented cylinder.
I note there seems to be an upper and lower unit, so would expect some method to switch between the two.
The lower heating element may not be heated outside of the cheap night rate times but the upper element should be available for maybe 24/7 but certainly should be available outside the cheap night time rate.
The OP might also clarify the statement "Every August my hot water stops Working".
Thank you, @jj4091 it is interesting as to what the unit does, not quite as complex as my iboost+ but getting close to it. Now we have to wait and see what @KittenInHouse says, I have not seen any pictures of a controller. There does seem some questions having read the instructions, but don't want to muddy the water.
Thanks the replies so far.
So the top immersion heater is for the boost water setting. The bottom immersion heater is for the regular hot water supply. In my head it's like two water supplies. In an Ideal world you Set the programme for timed boost (can do three) in middle of night (hot water in morning) then a top up boost in afternoon. The boost immersion heater hasn't worked since forever so hot water has always come From timed water. The horstmann electric 7 works fine lights on power on water heater on but I don't or Cant check voltage.
My Hot tap in my Sink is not producing any water and I wonder if air bubbles are stuck in the pipes? I got air bubbles from the hot tap but I was told this was unrelated. I would like to increase the water supply to the boiler but don't know how to do it.
I think the immersion element is gone kettle for baths for kids it makes me think to myself to be train as a Gas engineer
This is the most annoying thing of all. A stupid reset button that doesn't exist I've also increased temperature to max.
I do worry water tank is empty. Why 9t goes off late August maybe not related but I always go on holiday and when I come. Back do lots of washing don't think washing machine would impact hot water?
Oh I'm sooo stupid (girl brain) the red wire at bottom immersion heater has burnt out or disconnected so no power is going from thermostat how do I fix this red wire? The top wire is connected correctly but boast doest work
Can't see the bottom terminal of the red wire in your pics. The easiest way to repair will be to replace that length of red wire and the terminals if the bottom one hasn't burnt away. See if you can gently remove it.
Perhaps something like this may fit but you would need to ask them for dimensions ( length and CSA ) and confirm what that bottom terminal is.
Do you want to risk yourself and your two kids?
Unless you have some electrical experience and knowledge, which seems doubtful so far, I strongly suggest you get someone who knows what they're doing.
+1, Immersions pull a lot of current, it's already overheated, possibly arced out and melted the wiring. Get an Electrician to sort it out, and ensure it is safe. Could be down to poor installation initially as to why it's melted, or there could be another issue that needs resolving first.
Trying to bodge a repair if you are unsure what you are doing, at best could result in Tripping the Electric, at worst it could result in a fire or someone getting electrocuted. If you're renting, get the Landlord to fix it!
Electricians and plumbers are stealing a living with their outrageous pricing. A 10 minute job is 3 weeks food for 2 children. What the profession relies on is stupidity and do landlords actually use real qualified people . They bring in dirty feet, smell like a bin and message you a few days later on social media. The reason I'm suspicious of the profession Is when my boiler went in my. Old house I trusted the industry and he told me it would cost me around £8k to fix as boiler was gone and new boiler needed. Are you absolutely sure???? Doubled down yes maybe you get a good price! In reality the fuse had gone (costs £2 to change). When I told him that the fuse was dead he hung up the phone.
The only living that does a worse job are pest Controllers.
