- Joined
- 5 Sep 2026
- Messages
- 5
- Reaction score
- 0
- Country
I don't know where to start. Every August my hot water stops Working. Nothing trips nothing has tripped resulting in any power Being lost that couid change the water. But now I can't get it back on. I'm a single mum with two kids (4 and 18 months) I can't afford a plumber. The Hot water works used to work for timed programme but the hot water hasnt worked on boost For a long Time. If I try Boast the water will always be cold.
The water system is controlled by a horstmann electric 7. The power supply works. The lights are on. Everything comes on. The water just doesn't heat up. I've Spent hours and hours and hours trying to resolve this.
Within the immersion heater, I've turned off the power supply to reset the thermostat. There seems no reset button. The temperature has been changed to plus. The water just wont heat up. I've Added Some pics and. To confirm again I've always got power supply Off when playing around with immersion heater. I took the stuff off to identify reset button with screwdriver but there is nothing
