Compression Waste is Universal and fit fit almost anything of the appropriate size. Solvent Weld is far superior though, if you're up for having a go, just assemble everything dry, mark the positions across the pipe and the socket to line it up when you make the joint as you don't get very long!
Great advice until you try dry fitting!
Don't know what brand you use buddy but most of what I use, only goes home when lubed with solvent cement and then it's final!
Try a dry fit and it's a ******* to release!
FFS!
