Kitchen sink waste advice
Compression Waste is Universal and fit fit almost anything of the appropriate size. Solvent Weld is far superior though, if you're up for having a go, just assemble everything dry, mark the positions across the pipe and the socket to line it up when you make the joint as you don't get very long!
Great advice until you try dry fitting!
Don't know what brand you use buddy but most of what I use, only goes home when lubed with solvent cement and then it's final!
Try a dry fit and it's a ******* to release!
FFS!
FFS!
Don't do much these days but I share your pain. I usually just try and get the pipe into the socket enough to hold the position, allow for the bit extra that isn't in the socket and experience tends to help with the rest!
Had to take drastic action yesterday.
Big house refurbed in 2023.
Builders put no SVP in at all - not even a durgo and his bogs and drains get regularly blocked.
Opened a manhole and away it went, so I put in a temporary vent at the only place I could!
If all is good for a couple of months I'll be redoing this whole monstrosity of pipework to go through the roof instead of around it and will put a proper SVP in.
Thanks again chaps, I’ve bought a 50mm core bit so that’s sorted. All pipes were blocked with gunk - and I’m careful what I put down there!
I’m thinking of having the waste pipe on the right, the washing machine waste is closer that way and it’s away from copper pipes. Should I shorten the upright (to strainers) pipes?
Oh and dilalio, don’t get me started on my soil stack
Yes - no need to have the drops into the main body of the waste system so long. Shorten them by at least 50%. They are designed to be shortened to allow a good fit to an existing outflow.
Unfortunately no amount of shortening can make it level with the existing waste pipe, even though it lines up perfectly. What a shame!
Think I’ll replace my SDS drill with one that has a safety clutch tomorrow. Don’t fancy snapping my wrist. Need to do one in the bathroom soon so will be worth it.
