It's fed from the load side of the top board main switch, so there is a single point of isolation.
RF Lighting said:mdbalson said:What's wrong with BS951 Clamps on the incommerAs I have a BS951 Clamp on the incommer at home.
It can crush the cable, and BS951 clamps are not designed for use on cables. (They do not always provide the most reliable connection)
equitum said:"Safety Electrical Connection - Do not Remove"
Looks like someone ignored the warning label ....... and removed the label !!
Next Inspection Label ?
Circuit Schedule ?
mdbalson said:equitum said:"Safety Electrical Connection - Do not Remove"
Circuit Schedule ?
who's picture are u talking about![]()
RF Lighting said:I removed the warning label as it is not required by BS7671![]()
equitum said:RF Lighting said:I removed the warning label as it is not required by BS7671![]()
I thought it was required, for my benefit, can you elaborate ?
On the subject of labels, I also thought the label "Danger 240V" is not required by BS7671, but you have not removed this from one CU (or have stuck it on one of them)
Next Inspection label
and Circuit schedule ?
RF Lighting said:The suppliers cable and therefore the suppliers MET is governed by the ESQCR regs, not BS7671.
It is affixed to the inside of the CU lid along with the 'test RCD quarterly' and 'how to reset a device' stickers.
The photo was taken upon completion of the installation work. I type up the schedules and test certificates on the computer once the installation work is finished.
A printed out, laminated schedule is much neater and more durable, and also has company details on it![]()
