Connecting HOB & Oven
3 Mar 2005
Surrey
Could you guys give me some tips on how to connect an electric hob and under oven (under the hob).
I have an adjacent 45amp cooker circuit with switch and a 45 amp load side cable that coming out of the wall below the switch, behind where the oven and hob are goinng to go.
Do I insall some sort of cooker connecting block and wire in the hob and oven with heat resistant flex cables ?
or what ?
the hob is it gas? if so that cable should go into a socket, its for your ignition.
oven should go into a cooker oulet,
depends on the wattage of the oven for what size hr flex
