wring in seperate oven and hob
2 Sep 2004
Hi
I have a 30 amp 6mm supply to a 45amp cooker point/switch and then 6mm wire to the hob and oven space.
hob is 7.1 Kw and oven is 2.1Kw
how do I connect these two together so that they are both running on the same circuit?
or do I split them out one on the cooker circuit and another on the ring main?
do I need to run 6mm cable to each unit or can I put the 6mm cable into a junc box and then run 2 different cables fron there to the oven and hob?
If they are close enough together, you could use a CCU with a socket, comme ça:
(other makes and other suppliers are available)
and wire the hob to the cooker switch and plug the oven in.
Plus do a search here for cooker, hob, oven etc and read all about wiring two appliances to a cooker outlet plate, and about whether you should have them on a 40A breaker. 40A is interesting - depending on the length of the cable, and whether it's buried in conduit, or bunched up with other cables, the existing 6mm cable could well be OK for it.
