Central Heating Timer
12 Oct 2007
I have recently replaced my Honeywell ST699 timer with a new one, unfortunately since fitting nothing works :( !!!! There is no display on the timer and it does not reset. would it be possible that it is a faulty timer??? :shock: It is in a S type circuit :roll:
Have you replaced with a ST699 :?:
Have you wired like for like :?:
Has the fuse popped in spur :?:
OK,OK enough Q an A.
Is there live to the timer and a sound nuetral.
It is posssible to purchase a brand new dodgie timer :evil:
Sorted, the hot water auto valve switch was welded in the closed position and there was a fault in the programmer switch for the hot water. So engineer has replaced both and everything is now working. HAPPY DAYS :D thank you clf-gas for your help :lol:
