hello.
I'm trying to install a heatmiser prt volt free switch inplace of a drayton thermostat.
i have removed the old thermostat and tagged all wires up.
The wires were as follows
NEUTRAL =grey/blue wire
LIVE= brown wire
Call= brown/black wire.
When i come to wire the prt up
LIVE = L
NUETRAL=GREY/BLUE.
I dont understand were call wire goes does it go to a1 or a2.
I have wired them up in either of these and the heating does not come on when its called for.
Also the electronic time switch is set to on
So i am wondering
1. do i have the right unit.
2. do i need to put an extra wire in from somewhere
3. do i need to block earth off.
Also when i turn the electronic time switch off, the prt goes off and theres no power to it.
I have a ideal condensing combi-boiler isar combi.
the timing unit is a tempus 2 electronic timeswitch.
and the thermostat is a drayton
i thought it would be relatively simple to install as the website stated that if your stat has 2 wires not including earth, it should be straight forward swap.
As you can see i aint very good with electrical know how.
But any info would be appreciated
i have included the website with the wiring diagrams, as i cant copy the wiring diagram i want
http://www.heatmisershop.co.uk/images/new_prt_series.pdf
its the picture with page number 24 its the prt volt free switching.
MANY thanks
LIVE= brown wire
LIVE = L
NUETRAL=GREY/BLUE.
So i am wondering
MANY thanks
