help identifying boiler part
4 Feb 2006
hi all i need some help identifying a part on my boiler it looks like the thermo couple it goes in near it and when I remove it and press the ignition gas comes out any ideas the other end goes in to where the ignition spark is its about 12" long thin tube thanks
Sounds like a pilot gas tube.
Make and model of boiler would have helped :roll:
when i took it out the end fell under floor boards so i need to get a new one my local plumb center did not have one so i am trying get one online thanks
if thats what its called pilot injector yea the end fell of about 10mm long and goes into the boiler
If you took off the pilot gas feed from the pilot assembly then I think you have lost the injector.
Was the pilot not igniting.
Sounds as though you have gas to pilot and the lost injector was blocked. :cry:
Thinking about it, it may not be the injector rather the injector seating, the bit that sits on the end of the pipe above olive and knut,
no pilot not lighting but i will need to get anther one is this the right one
Baxi 225492 Pilot Injector thanks
thanks for that link i have at this all day tring to find that part superb :lol:
