Solution for stopping the noise of a tank filling
9 Apr 2006
Hi, is there anything out there to stop the dripping noise when the cold water tank is filling.
What I mean is there any device that means the water fills from a few inches below the water surface? Like a simple tube or pipe to take the feed under the surface?
Could I just fit a piece of pipe onto the normal setup?
Just had a loft conversion and we will be much nearer the tank so want to get it as quiet as possble.
Ta
yep, short piece of pipe will work. they do the same in toilet cisterns
Ahh Cool. I was thinking that would work but wanted to check if there was any reasons to not use that method.
I assume there is no way that having the supply below the water line with a pipe can cause any contamination problems in the tank as the water will no doubt be more still?
Thanks,
fitting a tube to ball valve will remove the air gap in the tank that is required by water regulations to protect against back syphonage
so if you installed a pipe with a small hole drilled in it, it would be fine, since you cant create a vacuum with a hole in the pipe.
Rigid pipe used to be used in water cisterns for this , but was replaced by collapsible plastic stuff to prevent back syphoning.
i have seen that, i honestly thought it was to cut costs.
so there is the answer to the question, a bit of polythene pipe.
now you point it out is obvious, the pipe will colapse if it syphons
So where can one get some of this polythene pipe then?
Thanks for all the comments.
local plumbers merchant.
might be easier to change whole valve with new pipe
