new boiler
15 Apr 2005
Yorkshire
Right guys, BG have been to quote for a new boiler, and its left me with questions . . .
1. Is microbore pipe (8mm) a bad thing (we have this, installed about 18 years ago)?
2. Boilers without pilot lights - do they click to ignite whenever theres demand?
3. Are Worcester Bosch boilers available with digital wireless stats instead of the mechanical one BG want us to have?
4. Whats the opinion of putting a boiler in the loft? If all the microbore has to go, we might as well move the boiler from its current location in the kitchen.
5. Will the 15mm gaz pipe need upgrading? I have read 28mm being mentioned :shock: Our old worcester electronic 2.4 has a 15mm gas pipe, and the new boiler wont be any more powerful. The length from the meter is about 11-12 metres, about the same to the loft, but upwards!
6. Should we have plastic pipework put in?
Likely to be sludge inside and you should change after 18 yrs. 15 mm will heat up quicker and would be my choice.
Presume so
I put mine in the loft to free up space in the kitchen. You have to board it out and fit lighting, guard rail etc.
Definitely.
Your choice. :D
Definitely.
Why though? Why was 15mm acceptable 18 years ago, but not today? What is the difference that requires bigger pipe on new boilers?
I think I could manage to board out the loft and fit a HF fluorescent light and loft ladder.
Its to do with gas rates and safety.
One of the Gasmen will tell you more than me though......................
OK i understand that now. Thanks.  8)
Another question, why do BG quote for an electrician to upgrade the main bonding, when it is already in place, and they could see its already in place! The guy who did the quote said if the electrician arrives and finds the MEB is already in place, the £130 cost will be deducted. This is a DIY job anyway, but this option wasn't mentioned to us. We are going to get more quotes. :lol:
You should be able to read up on earth bonding and see for yourself if its there.
A 10 mm earth on the gas pipe at the meter is a good start.
Tony
