I am converting my garage to a dining room and would like/need to reroute the gas pipe from the gas meter (which is in the garage) underneath the floor of the garage/dining room. The floor is currently concrete but will be built up about 190mm with polystyrene/styrofoam (not concreting to save a few pounds (the garage will eventually be demolished and a 2 story extension built which will need a new footing (hence not wanting to spend money on something that will be ripped out 3-5 years down the line).
My plumber is insistent that the ducting for the gas pipe needs to be a special "made for the purpose" duct vented at both ends. I don't have an issue with the venting but wanted to know whether any type of ducting that protects the gas pipe is OK - for example a length of waste pipe?? Or a timber (narrow) box. I also know that the gas pipe must not have compression fittings.
Any thoughts on what is and what is not necessary?
