battene battens battens
26 Oct 2007
London
Sorry for a noobie question but I have decided to install brushed and oiled oak over old concrete using battens. Can anyone please tell me what size, material battens to use and if wickes is a good place to get them.
Thanks a lot
Battens at least 50mm high, nails at least 50mm long.
Battens not further apart than 35 - 40cm
Tini - we always use treated battens in this situation. If it's a very big area and you are intending to fix the battens consider hiring a Hilti cartridge nailer, with appropriate fasteners. How will you fix the boards down - secret nailing I hope? Oiled oak - you've made a good choice!!!
Thanks alot for your quick reply .. was thinking that means my floor will rise by 7cm !
Is there no other way!!??
Good tip about the cartridge nailer too, thanks as well, and yes, I was going to hire a portanailer, or buy one from sfx and flog it when i finished!.
By the way, as for treated battens.. what do I ask for... "treated battens?" Thanks, AW
Tini - ask for treated battens or tanalised battens, same thing.
You could use thinner battens as they are resting on & fixed to the concrete - we use tile battens (2 x 1) where the 1" is the height.
Symptons, question for you re 2.54cm high battens. When you nail your 50 - 55mm long nails in an angle when secretly nailing, doesn't the nail hit the concrete????
WYL - an excellent question! No they don't 'cos we use cleats of different lengths according to the job in hand. 38mm long, 45mm long, and of course the bread & butter 50mm long.
WYL - I sense you're trying to catch me out .... :cry:
Anyway, 19mm thick, say 6mm approx tongue, cleat entry point say 11-12mm up from base of board, nominal 1" thick batten which in reality is 22mm thick. Apply a bit of Pythagoras and you come out with a 45mm cleat which would not break through the batten, or we could sized-up by eye. In reality a thicker batten, and longer cleats is always the way to go but as Tini is short of depth 2x1 is a satisfactory option.
Interesting observation however, 50mm cleats tend to deflect/bend horizontally when hitting the concrete so would work, but they'd be a bu**er to get out.
test of your knowledge maybe symptoms. As big al says ' we are all still learning' At least i think thats what he says or is that someone else on here? But woody does seem to be a bit of a guru on the old wood installs. :D
Not at all Symptoms, just wanted to hear more about it - hear to learn too, as everyone else. ;-)
Besides that, we hardly install on battens on concrete, still think it's a waste of money, effort and height. But that's just me ;-)
and me, plus a weak point if the batterns leave the floor.
Matty - of course correctly fixed battens don't "leave the floor". I suppose as there are no regulations regarding this type of work, only 'good practice' and that based on experience can guide us. When ever we've been called to offer this solution, done properly it'll stand the test of time - we've been at this game now for 34 years. Anyway, the OP specified battens and all/most posts are in this connection.
Hello again.. woodulike.. can you tell me how YOU install wood flooring over concrete..? i thought battens were a must.. (there are some slightly uneven surfaces in the flat)
and Symptoms, to affix battens, if that is what i use, can you explain how to use that a Hilti cartridge nailer and show a link to appropriate nails?
again everyone!
