have to wire up some stuff
31 Oct 2007
Renfrewshire
Hi guys and girls :D
need to do some wiring and drew up a wee picture  8) any thoughts on this :roll:
Picasso re-borne
But seriously while the content can be derived it is not easy to do so and even you in a years time will probably have trouble trying to understand it.
Whether the content is correct or not I cannot comment.
I will make one comment,
Does SAN indicate Saniflo pumped sewage system and if so are there only two toilets both wth Saniflos ? If so I would NOT put them both on the same circuit just in case you lost power to both and repair was going to be some time.
:wink: good thinking batman, will redo that bit then :D , and as for the drawing it was somthing I done in 2 minutes, but will redo in autocad when I get the chance.
The lighting circuit appears to be a ring, which is not usual.
had a look at the drawing again, will this work :?:
sanitop 550w fed by fcu
handwash 3000w fed by fcu
hand dryer 2000w fed by fcu
running on a 2.5 t@e ring
