HOT WATER CYLINDERS
3 Nov 2007
Perthshire
DOES ANY-ONE KNOW WHERE I CAN FIND A SUPPLIER OFF A TRIBUNE II
HOT WATER CYLINDER AS I HAVE TRYIED A FEW LOCAL PLUMBERS
MERCHANTS IN PERTH AND THEY GOT THE CYLINDER WRONG EVERY TIME I NEED THE CYLINDER TOO HAVE BOTTOM FEED -TWO IMMERSION , ABOVE THIS TAPPING FOR RELIEF VALVE AND AT THE TOP FEED TO HOT WATER TAPS FOR GOT TO SAY SYSTEM IS A DIRECT ONE:, I HAVE HAD A QUOTE FOR STAINLASS STEEL BUT DON'T KNOW WHAT THE TAPPINGS ARE ON THE CYLINDER CAN-NOT GET ANY ONE TO LET ME SEE A BETTER PICTURE ON WEB-SITES OF SUPPLIERS:
your plumber can advice on the best for you as these are a unvented system and you need a g3 cert to work on them
THANK YOU FOR YOUR ADVICE I HOPE TO GET THE TYPE OF CYLINDER THAT IS FITTED BUT I HAVE TO GET A SUPPLIER BUT THIS WILL HAVE TO WAIT UNTIL MONDAY KNOW AND I WILL HAVE TO CHECK WITH PLUMBER THAT HE HAS G3 CERT?
