In another post Megawatt said
I have seen this argument many times and it really does not hold water.
If you look up "Should" in the Concise Oxford Dictionary you will find several definitions including:
1. Used to indicate obligation, duty or correctness
with the subsidiary meaning of:
used to give or ask advice or suggestions
I think you will find that a Court of Law will take it to be the "obligation" definition rather than the "suggestion" one which is intended here. Though you can always try your luck in court and prove me wrong.
In any case, if what you and others say is true then there is no need to do anything. NO condensing boilers, NO insulation, NO double glazing etc.
The route which gives the DHCR legal status is as follows:
1. Building Act 1984, which allows the Minister the power to make regulations and issue Approved documents to expand on the Regulations
2. The Building Regulations made under the powers in 1.
Section 35 of the 1984 Act says:
Any person contravening a provision contained in the building regulations is liable on summary conviction to a fine not exceeding level 5 on the standard scale laid down by the Criminal Justice Act 1982.
3. The Approved Documents made under 1 which puts the meat onto the Building Regulations.
The APs are given legal status by the 1984 Building Act
and finally the Domestic Heating Compliance Guide.
And even here there is no get out.
The Building Regulations only say:
Reasonable provision shall be made for the conservation of fuel and power in buildings
A very vague phrase! What exactly is reasonable? And we look in Approved Document L and we find:
Reasonable provision for the performance of heating and hot water system(s) would be:
a. the use of an appliance with an efficiency not less than that recommended for its type in the Domestic Heating Compliance Guide; and
b. the provision of controls that meed the minimum control requirements as given in the Domestic Heating Compliance Guide for the particular type of appliance and heat distribution system
So there we have it. If you want to meet the "reasonable provisions" stipulated in the legal Building Regulations, you have to meet the minimum standards laid down in the Domestic Heating Compliance Guide
Yes it is but, as has been discussed many times on this forum, it is a guide not a law.It is all explained in the Domestic Heating Compliance Guide at:
http://www.planningportal.gov.uk/uploads/br/BR_PDF_PTL_DOMHEAT.pdf
The reason it is a best practice guide and not enforceable as a law is that it has Should's rather than Must's which have entirely different legal implications ... Read it again and see what I mean.
See how many ... You MUST do this's you find and let us all know![]()
MW
