Let him go ahead, the in-rush current to the TV will probably take out the MCB enough times for it to be annoying.
If a CRT then the inrush current as bernard points out could be sufficient to take out the MCB, The other worry might be whether the lighting circuit is on a dimmer![]()
Or the screen to go dimWell, I am guessing he is going to pick up a perm live - Dont want the telly going off when he turns the light out!![]()
While operating yes if not a massive TVIn fact it will draw less current than 4 X 50W Low Voltage downlights.
A beautiful installation that doesn't work well is not worth the troubleAs I said it's not good practice but if it means saving making a complete mess of your room do it.
.How many contractors fit a socket in the roof for a TV amp that must be fused at 3A and connect this into the lighting circuit,
How many contractors fit a socket in the roof for a TV amp that must be fused at 3A and connect this into the lighting circuit, I have seen this many many times over the 35 years I have been in the trade.
An electrician down the pub. Is it true?
Don't worry been on the screwfix forum. They say you can do it. YOUR OBVIOUSLY NOT AN ELCTRICIAN ARE YOU?
