Does my system need a flush?
  • Thread starter Thread starter Deleted member 54734
  • Start date Start date
D
It's the cold time of year again and I decided to bleed my radiators before they are on constant use for the mrs.
I bled them ok but when I did I got a lovely black mess out of them, I've also noticed that the hot water seems to be murky white when the taps not opened fully.
I have not got a clue about Central heating at all and this is the first house I've had it in, but It seems to me it needs a flush does that sound right?
If not a flush is there a way I can clear the hot water up?
Bearing in mind I haven't a clue on central heating, is a flush something I can do my self or is it worth getting a plumber in?
I think I have a closed system with a gas boiler in the kitchen and a hot water tank in the airing cupboard upstairs, don't remember seeing anything in the loft the last time I was up there but I may be wrong.
Roo
Yes, you need a flush.
No, do not do it yourself if you are not experienced with central heating. There is more involved than simply getting the dirt out.
Find yourself a local chap with good reputation, get him to clean the system and service the boiler. Over time you will probably safe yourself money, and surely large amounts of hassle. The vast amount of my work is repairing the results of diy, poor workmanship and lack of maintenance.
