No hot water - will flushing the system fix the problem
17 Feb 2007
Cheshire
Our hot water no longer kicks in via the timer - only when you switch on the emersion heater.
An engineer has been out and can't find a fault and says that the water in the system is dirty and will need flushing as there could be a blockage.
I'm confused, why would flushing the system fix the problem - I would have thought flushing the system would clean the central heating system, i.e radiators, but how does this tie in with the hot water system, (from tap).
The switches have been changed as originally thought these were at fault, i.e. not heating water at desired time.
Any clues.
The heating circuit also loops into your hot water cylinder via a coil this my be blocked.
Check and see if the pipes leading to and from are hot.
It may also be a simple faulty motorised valve .
As Scatman says need more info on your system to be more exact.
Pete
The system is ...
Appliance Type C/Heat Boiler Olympic 20/35B
GC Number 4178921
They suggest a Power Flush of the system which should resolve the hot water, (from tap), problem. Also, radiators upstairs need bleeding constntly so should resolve this as well !
Being quoted over a grand for the work. Does this sound right for a small semi.
Cheers
Rogue Traders territory. Find another plumber!
Could be a motor costing less than £20 in the sheds...
£1000 for a powerflush and I thought London prices were steep.
For a 3 bed semi with up to 10 rads we charge £420 including all chemicals and final add inhibitor.
Pete
