Our hot water no longer kicks in via the timer - only when you switch on the emersion heater.
An engineer has been out and can't find a fault and says that the water in the system is dirty and will need flushing as there could be a blockage.
I'm confused, why would flushing the system fix the problem - I would have thought flushing the system would clean the central heating system, i.e radiators, but how does this tie in with the hot water system, (from tap).
The switches have been changed as originally thought these were at fault, i.e. not heating water at desired time.
Any clues.
Any clues.
