Hi, can anyone help me?
I'm going to install 6 downlighters in my kitchen. I plan to daisy chain them together from a 20a junction box using 1mm twin and earth lighting cable. My questions are...
1. Is the 1mm cable suitable for 6 downlights (50W bulb)
2. The fittings are double insulated and 'should not be earthed'. Should I simply snip off the earth core and leave it?
3. The actual connection box on the fitting is small and it is really difficult to connect 2 cores into each 'terminal'. So I bought some 15A connector strip blocks and planned to make the daisy connection in to one side, and take another short length of cable from the other side to the fitting. Is that a sensible/safe idea? Or should I squeeze them into the terminal as best as possible?
Many thanks for all reponses!
