Radiator flow
LVH
24 Nov 2007
Hampshire
Recently brought a house. Radiator valves were leaking, therefore replaced all manual valves with TRVs and Lockshield valves (in same place as manual). Heating now going through the outlet first i.e lockshield. Unfortunately not sure which way flow went prior to change. Is this OK? Is this normal? Any comments welcomed. Confused!!!
Though it should not matter with bi-directional valves, I have found that some brands are easier to balance when all fitted on the same side. There is definitely no down side to sticking them all on the inlet side, so you might as well swap those that are on the return side.
