I have an existing system which is working very well. Condensing boiler, pumped system ,conventional indirect hot water tank in airing cupboard, rads in most rooms. My question is I would like to add a radiator in my conservatory. The existing system is 15mm but I would like to use 10mm microbore for the extra rad. I have located the tapping positions and the pipe run would be much easier if I can use 10mm. If this is not adviseable I will do it with 15mm.Is there anything special for me to look out for when restarting the system after fitting
many thanks
many thanks
